Keith_Beddoe
Message 51 of 65
Re: FTTC connection 300 feet from cab poor downstream
I suppose a faulty home hub could be causing the issue, if the frontend circuitry was generating noise?
Swapping the home hub with another, would prove that.
Or you could just have a bad cable pair.
DanielS
Moderator
Moderator
Message 52 of 65
Hi @stoswald,
We can run a few tests from our side and try work out what's causing this. To get in touch with us, click on my user name and then on contact the mods. Make sure you change the site view to Full site view instead of mobile before you can see the contact link.
DanielS
stoswald
Message 53 of 65
That would be great Daniel, however I can't see a contact the mods button (using Edge on my PC)
Starwire2000
Recognised Expert
Message 54 of 65
Do you know if it’s an ECI or Huawei DSLAM?
imjolly
Message 55 of 65
Rugby 7 is huawei
Keith_Beddoe
Message 56 of 65
@stoswald
This picture will show what to look for Moderator contact link image
stoswald
Message 57 of 65
I don't see the moderator contact image when I click on his name DanielS or DannyS, just wonder if I haven't been invited yet?
Keith_Beddoe
Message 58 of 65
He is probably offline now.
I will ask a moderator to post another link, but it will be tomorrow.
stoswald
Message 59 of 65
Could I also report the ethernet lights on the rear of the HH6 donot show light up.
Keith_Beddoe
Message 60 of 65
That does sound like a faulty home hub. I would mention it on the contact form when you get the invite.
A faulty home hub power supply or circuitry, could cause interference or poor performance.
