Showing results forΒ
Search instead forΒ
Did you mean:Β
Distinguished Guru
Message 11 of 24
Re: FTTC speeds at peak times
In order to rule out the Homehub as potentially being the device responsible for your speed loss, you can connect the Openreach modem directly to the PC and see if the speed improves.
To do that follow these steps:
Step 1: Remove the homehub from the modem cable
Step2: Connect your pc/laptop to the modem via the cable instead
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Username bthomehub@btbroadband.com and the password as BT
Step6: connect, If it doesn't,keep pressing try again until it does.
However, please note that this will stop any other access apart from the PC
If not, I'll try again πŸ™‚
Tags (1)
spann87
Message 12 of 24
Ray,
I'll have a go later thanks - however, this problem has persisted through three different homehubs so I'm not expecting wonders!
spann87
Message 13 of 24
It does sound like my problems are very similar to the ones in this thread:
https://community.bt.com/t5/BT-Infinity-Speed-Connection/FTTC-speed-at-specific-times/td-p/1336823
Distinguished Guru
Message 14 of 24
The direct connection test rules out the Homehub as it's not connected. It's the obvious test to do if the Homehub is suspected πŸ™‚
spann87
Message 15 of 24
Thanks Ray, I'll try later.
spann87
Message 16 of 24
One more question: Would Congestion also affect my upload speed? Upload speed is frequently faster than download speed.
spann87
Message 17 of 24
Connected the VDSL box direct to the PC, no change.
BT have decided a third engineers visit is needed.
Current speed according to speedtest.net is 2.71 Down, 8.08 up with a ping of 16ms - Only me in, nothing else connected to the router.
spann87
Message 18 of 24
BT engineer has just rang me (I'm at work) - he is baffled because everything seems fine!
He's spoken to BT wholesale who told him I needed to do tests via the wholesale checker - which is what I did three weeks ago to get the first engineer out.
I'm at the end of my tether here. Can ANYONE help?
spann87
Message 19 of 24
Engineer has phoned again - he says it could be radio interference which could be coming from anywhere on the street.
spann87
Message 20 of 24
Engineer has phoned again - he says it could be radio interference which could be coming from anywhere on the street. I don't know what to do anymore.
