Message 1 of 3
FTTH area but can't order
Upto about a month ago I could order FTTH but now can't. On the availability checkers nothing is now showing for FTTH. The best bit is that the fibre cable runs across the front of my property (Approx 20ft from the building) and a overhead cable about the same distance to the rear. My next door neighbour had it installed 2 week ago.
Using the checker with a address it seems all the even numers can order (other side of the road) and my side (Odd numbers) only about every 5th house can order. Seems a bit strange anyone else had a simular problem?
2 REPLIES 2
Sage
Message 2 of 3
Re: FTTH area but can't order
Ring the FTTP sales team they should be able to advise you. 0800 587 4787
Message 3 of 3
Thanks will give them a try later.
