Whittdawg
Newbie
Message 1 of 6
FTTP - 1st Floor Install
Hi, We are in the process of having FTTP installed on our estate, does anyone know if it is possible to get the modem and router installed on the 1st floor of our property rather than by the front door (which is where the old BT line comes in) ? I'd like to have everything installed in my office and out of sight rather than right next to the front door. Thanks
5 REPLIES 5
Message 2 of 6
Re: FTTP - 1st Floor Install
You mentioned an office, is this a business connection, as there is usually more flexibility allowed on a business premises?
Whittdawg
Newbie
Message 3 of 6
It's my home office, so residential connection not business
Message 4 of 6
I think you may have to wait and see, but one of the other forum members may be able to advise.
Distinguished Guru
Distinguished Guru
Message 5 of 6
The FTTP engineers are normally pretty flexible. They will discuss the installation with you and will try their best to meet your needs.
As an aside you must make sure a double scocket is free for the ONT and battery backup. You will also need one for the router. If you are placing the router elsewhere in the room make sure you have an ethernet cable long enough to stretch frum the ONT to router.
Whittdawg
Newbie
Message 6 of 6
Fingers crossed then, no issues with sockets in office but only one near front door (which is one of the issues)
