Message 1 of 3
FTTP 900 Issues
Hi all,
First time posting on this forum. I got Fibre 900 installed today as my previous speeds were around 50mbps download and 20 upload. MGALs when I upgraded was 700mbps download and, for the price difference, i felt it was worth it.
At one point today, my wireless download went to just over 150mbps and upload was around 120. I've now did a speed test using OOKLA and I'm sitting with a measly 46mbps downloaded however the upload is sitting at 65. I know there's usually a period of time for the speeds to settle (10 days I believe). Having spoken to people who recently had it installed, they said their wireless speeds were 400/500+ after the first day of installation. Is this normal to see the speeds even lower with FTTP 900 than when I was on regular fibre? Obviously I know if I ring tech support they will likely tell me to monitor it over the next 10 days I'd imagine for the speeds to settle/optimize.
Thanks.
2 REPLIES 2
Message 2 of 3
Re: FTTP 900 Issues
What speed do you get downloading over an ethernet connection not wireless which is subject to interference
Message 3 of 3
Re: FTTP 900 Issues
Thanks for your reply - I haven't had the chance to do a wired connection as of yet. Completely appreciate things even as small as dimmer switches can cause interference with wireless but thought the discrepancy between 150 down wireless today versus 45-48 down whilst remaining in the same room was a bit concerning. Will do a wired test tomorrow and update 🙂
