MikeBradshaw
Message 1 of 10
FTTP, Apple ans Smart Hub2
Hi, Ive got fibre to the property (300mbps). I use a lot of Apple products and I've just upgraded to the smart Hub 2
I've been told by BT that the max I can get with Apple is 65mbps on the Smart Hub 2
Time Machine on Apple now also doesn't work because of the inability to split the channels too
BT advised me to look an the Apple support pages
Has anybody got any more useful advice and ideally a solution?
9 REPLIES 9
Message 2 of 10
Re: FTTP, Apple ans Smart Hub2
What have you 'upgraded' from?
No idea why you have been told that, the hub has no idea what equipment is connected to it.
Not sure what the problem is with Apple devices and common SSID between wifi bands but the solution is with Apple. It is possible to turn off the bands individually on the SH2 however.
A third part router?
MikeBradshaw
Message 3 of 10
Hi,
Thanks for the reply
I was upgraded from a Smart Hub1. Speeds were quicker and I didn't have the Time Machine Back Up issue
The solution might be with Apple but they won't offer any support.
I also have the issue of Netatmo, Ring, Alexa, Smart TV's etc needing different bands e.g. Ring has to be on 2.4ghz
Do you know of any 3rd party router that will resolve this please? I stupidly also sent my Smart Hub 1 back for recycling 😞
Sage
Message 4 of 10
Virtally any 3rd party router will overcome the problem. It depends on what advanced settings you want and price you are prepared to pay.
MikeBradshaw
Message 5 of 10
Thanks,
Just looking for one that works with Apple @ 300 MbPS and has split channels. Any suggestions please?
Message 6 of 10
As @pippincp says, virtually any device will do. You only need a router rather than a combined modem/router. Have look at the Tp Link range possibly best to avoid Netgear products as they don't support BTs implementation of IPv6
MikeBradshaw
Message 7 of 10
Thank you
Please forgive my ignorance as I'm a novice to this. Would I still need to use my Smart Hub as a modem in conjunction with a new router?
Regards
Mike
lifeonmars
Message 8 of 10
I would suggest, switching off smart set up tab on your smart hub2. (and Keeping it off)
Also switch off 5Ghz on your Smart Hub2
Connect your devices. Keep Smart set up switched off however
switch back on the 5Ghz on the Smart Hub2  and see how you get on
If changing router  you will need one that has a FTTP Port
Sage
Message 9 of 10
You do not need to kee the SH2. Just connect the new router WAN port to the ONT.
Message 10 of 10
Bear in mind, if its a new contract, you must not physically dispose of the SH2, as its only on loan from BT, and will need to be returned, or paid for, if you leave.
