Garystan1985
Message 1 of 7
FTTP/FTTH installation problems
Hi, I just have a couple of questions regarding my FTTP order if anyone can help.
I placed an order for FTTP about 6 weeks ago via BT. Openreach visited about 3 weeks later only for them to say that they cannot install due to our overhead line being to long in distance. We had various problems due which I won't go into great detail about after switching providers and then being left without any internet connection whatsoever. We then placed a order with bt as agreed to have FTTC activated and then we would place the FTTP again which has been done.
My questions are: openreach have stated that a new carrier pole is required to provide the service to our property. Who covers the cost of this as we took a package deal through BT?
Secondly: Does anyone have any knowledge of how long it would take for a carrier pole to be installed? We live on a very busy main road. I'll also attach the results from the bt dsl checker website for your info.
Thanks in advance for any help.
6 REPLIES 6
Garystan1985
Message 2 of 7
Re: FTTP/FTTH installation problems
Garystan1985
Message 3 of 7
Starwire
Message 4 of 7
Because it’s an upgrade there is no cost to yourself.
brookheather
Message 5 of 7
If OR need traffic lights to be installed for the new pole expect a delay - can be weeks depending on the local authority.  You can check the https://one.network/ website (formerly known as roadworks.org) for details of upcoming roadworks in your area.
Garystan1985
Message 6 of 7
Thank you for that info.
Garystan1985
Message 7 of 7
Thanks for the info!
