Belfast_NI
Message 1 of 7
FTTP Fibre Package Upgrading
Decided to upgrade my fibre package from 50mb to 74mb.
Do I need to reboot my BT Home Hub 6 while waiting on the new BT Smart Hub 2 being delivered?
6 REPLIES 6
imjolly
Message 2 of 7
Re: FTTP Fibre Package Upgrading
no  when update applied hub will reset itself
are you on FTTP or FTTC?
Keith_Beddoe
Message 3 of 7
@Belfast_NI
No, both hubs will work anyway.
The change in speed is simply a removal of a software limit, so provided your line is actually capable of the increase in connection speed, the change in profile will be automatic.
I assume you have checked beforehand, that your line is capable of connecting at a  higher speed, by  using the availability checker?
Belfast_NI
Message 4 of 7
Hi,
Yes I have FTTP with fibre line coming into the house and ONT installed last year.
Keith_Beddoe
Message 5 of 7
@Belfast_NI wrote:
Hi,
No problem then, provided they send you the correct version of the Smart Hub 2, with the red WAN port.
Belfast_NI
Message 6 of 7
Thanks for the info, will check the hub for the red WAN port when its delivered.
Keith_Beddoe
Message 7 of 7
It should look like this at the back.
