Message 1 of 4
FTTP Hub UI
Just upgraded from GFast to Full Fibre 6 days ago. Is it normal in the hub UI to not see the DSL uptime. It isn’t a big deal as I can check the uptime on the status page, I just find it strange.
3 REPLIES 3
Message 2 of 4
Re: FTTP Hub UI
@McGrath1982
DSL refers to ADSL and FTTC connections, not FTTP which is optical.
Message 3 of 4
Re: FTTP Hub UI
You haven't got a DSL connection.
Message 4 of 4
Re: FTTP Hub UI
Thanks for the info it makes perfect sense now
