Message 11 of 32
Re: FTTP Infinity 2 only 10mbps upload issue?
It doesn't exist in FTTC, let alone FTTP.
The problem you have on here is that no one really has FTTP, even then, there isn't much help because there's no in home diagnostics you can do.
I assum you've reset the, ONT, Home hub and tested from different devices?
If all of the above has been done then it would seem like a configuration issue on the circuit.
Richyboy1974
Message 12 of 32
Reset everything (well powered off/on the ONT after disconnecting the battery backup), tried from 3 devices all exactly the same results.
I was thinking it's a configuration issue somewhere, it just doesn't help when the help doesn't know what they're doing.
I'll call them again tomorrow as the fttp team leave at 8pm.
Wish there was a dedicated phone number specifically for the fttp team, that would be a start.
Message 13 of 32
There is FTTP number (0800 587 4787
Richyboy1974
Message 14 of 32
Superb john46. Thank you so much!
Message 15 of 32
It is the one I use personally It sound like a possible configuration problem
Richyboy1974
Message 16 of 32
Message 17 of 32
Richyboy1974
Message 18 of 32
Oops, I accidentally hit post when I came on to get the phone number for FTTP.
Still no further forward with a fix. On hold at the moment yet again to re-raise the fault as the first fault was marked as 'Resolved'.
Sage
Sage
Message 19 of 32
Are you on FTTP @john46?
Richyboy1974
Message 20 of 32
Yeah, and apparently BT say upload is only 'up to' on FTTP.
