Showing results forΒ
Search instead forΒ
Did you mean:Β
Just_Liz
Message 11 of 29
Re: FTTP Infinity Speeds
And I definitely do not have a Ferrari πŸ™‚
It was already installed in the house when I moved in last month, but I didn't see the need to pay for 330MBps - bit of an overkill if you ask me for two people !
Distinguished Guru
Message 12 of 29
Have you split the SSID's so you can select if you're device is on 5GHz or 2.4GHz?
If not, I'll try again πŸ™‚
Distinguished Guru
Message 13 of 29
@Gribley
You're confusing FTTPoD with GEA FTTP unfortunately.
Message 14 of 29
Make sure you have turned off "Smart Set Up" on the Homehub. See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
You could also try giving the 2.4Ghz and 5Ghz frequencies different SSids. Just add a 5 to the end of the 5Ghz SSid so you know which is which. Check the 5 GHz Sync with 2.4 GHz: is set to NO.
Once you have done that "forget" the connection on your devices and then restart them and log onto both SSids.
See this link
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
You could try downloading and running inSSider. This will show you the wireless channels that your Homehub/router is transmitting on as well as the surrounding networks. You want to take a note of the channels in use and change your Homehub onto a channel that is not being used. Channel 13 is often the least congested on the 2.4Ghz. The 5 Ghz is not so congested so you could leave it on "Smart Wireless"
See Link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/14094/~/how-do-i-change-the-wireless-channel-on-my-bt...
See link for inSSIDer. Use the free version.
http://www.techspot.com/downloads/5936-inssider.html
Just_Liz
Message 15 of 29
Thanks both
The 2.4 and 5GHz channels both have different SSID names already.  Smart Set up on my HH5 was already off. Wirelss speeds on both of them are near enough the same.
This is the channel set up around here. I am on Channel 11 at the top.
I've no other electrical devices set up near my Hub.
Distinguished Guru
Message 16 of 29
Try channel 13 on 2.4GHz
Anything using 5GHz?
Just_Liz
Message 17 of 29
2.4 on 13 - but has made no difference to wireless speeds.
Yes, I'm also transmitting 5GHz but that SSID is not showing on InSSider for some reason
Distinguished Guru
Message 18 of 29
What channel is 5GHz on?
Just_Liz
Message 19 of 29
Its on channel 48 according to Hub admin
Distinguished Guru
Message 20 of 29
Maybe the PC with Inssider on doesn't support 5GHz
Have you thought about getting a USB wireless-ac dongle? That should run at up to 1300 Mbps as the HH5 supports wireless-ac.
