Just_Liz
Message 1 of 29
FTTP Infinity Speeds
Can anyone please help me with the easiest way to get BT to help me with my Infinity speed issues. I've just spent an hour waiting and 'chatting' to Live Chat Broadband Technical Help only to be told they can't help me because I'm on FTTP. They told me to call 151 tomorrow but won't that just put me straight through to the useless call centre again !?!
I've had awful speeds for a week now .. wired speeds are 12MBps with a ping of 27.
28 REPLIES 28
Distinguished Guru
Message 2 of 29
Re: FTTP Infinity Speeds
Can you post your IP Profile by running the BT Performance test at www.speedtest.btwholesale.com please? When the first test has finished, press the Further Diagnostics button then after you enter your post code and building number, your IP Profile should be displayed.
If not, I'll try again 🙂
Just_Liz
Message 3 of 29
Hi
My IP Profile is stated as 76.8Mbps
My upload test is performing as expected, with speeds of 19.25Mbps on a profile of 20
Distinguished Guru
Message 4 of 29
There used to be an Infinity Fibre support number 0800 032 0843
but it may have been discontinued.
Just_Liz
Message 5 of 29
Ok thank you. I'll give it a go tomorrow !
dfenceman
Expert
Message 6 of 29
Hi Just_Liz,
I'm no expert but those IP Profiles look remarkably like Infinity 2, i.e. FTTC, not FTTP.
Are you sure you are on FTTP ?
Best regards,
dfenceman
Message 7 of 29
As FTTP is available at varying speeds the IP Profile will be dependent on the package purchased
Distinguished Guru
Message 8 of 29
Infinity 1 and 2 are available on FTTP as well as Infinity 3 and 4.
Gribley
Message 9 of 29
FTTP is a fixed rate 330mbps.  If you have FTTP then you would only really have issues when the source site can not send that fast.
There is no vector/cross talk issuses if you really have paid out for fibre to door :)... I hope they didn`t scratch the Ferrari when they put it in 🙂
Just_Liz
Message 10 of 29
So I have the Infinity 2 Unlimited Package, but via FTTP. So the IP Profile matches what I'm paying for.  Just had BT Support on the phone and the wired speeds were just now 79MBps, but wireless was 8MBps.
They didn't know why my wired speeds for the last few evenings had been low, and now we start the rigmarole of trying to figure out why my HH5 is dishing out terrible wireless speeds.
They are looking into it being one of the following issues:
Windows 8 compatibility
"Other devices" in my household
Dual band channel SSIDs
etc etc
If anyone has any further practical advice, I would really appreciate it !
Liz
