Just_Liz
Message 21 of 29
Re: FTTP Infinity Speeds
OK, so that might work with my laptop, but what about my iPad, smartphones, sky box, apple tv etc
Everything is near enough wireless now, so if i get crappy speeds, then it makes life a bit more difficult.
I was getting consistently high FTTC wireless speeds at my last address about 2 miles down the road (and granted the BT cabinet was right outside my house), and now its meagre and I'm not sure why. The only that has changed really, is the fact I now have FTTP - which is supposedly miles better !
Distinguished Guru
Message 22 of 29
Ok, maybe you should be looking at a replacement for the HH5 then. There are many 3rd party routers with excellent reputations for good wireless.
If not, I'll try again 🙂
dfenceman
Expert
Message 23 of 29
Hi Just_Liz,
Aplogies for my earlier query.
You may find this useful :-
http://www.increasebroadbandspeed.co.uk/which-broadband-router-modem
Best regards,
dfenceman
Distinguished Guru
Message 24 of 29
I don't think either of those are useful in this situation TBH.
Distinguished Guru
Message 25 of 29
This is what I get on a Macbook Air running Win 8.1 on 5GHz wifi on my HH5
dfenceman
Expert
Message 26 of 29
Hi Ray,
I bow to your superior knowledge but what is wrong with them please ?
Best regards,
dfenceman
Distinguished Guru
Message 27 of 29
High Price for a router
Not very good wireless - no AC support
One has an ADSL modem the other is VDSL - no use for FTTP
Better routers are available
Netgear R7000 Nighthawk AC1900
Asus RT-AC68U
TP-Link Archer C7 AC1750
dfenceman
Expert
Message 28 of 29
Asus RT-AC68U
Hi Ray,
Thanks for that, I will pass your comments on.
Best regards,
dfenceman
Distinguished Guru
Message 29 of 29
Pass them on to Mark Heath? 😉
