Message 11 of 18
Re: FTTP failed install due to "fire risk"
My walls have no cavity, they are solid and 12" thick. There are random chunks of flint buried inside them so it's pot luck as to whether you can drill into the location you attempt because if you hit a flint then all you do is heat up your drill bit until it glows.
Message 12 of 18
Message 13 of 18
Yes, I read that the first time.  It was the description of the window in a 6 foot, grill covered hole that set me thinking.  If I'm wrong then fair enough.  I'm off to bed.  Hope you get it sorted out, my friend.  Good luck.
Message 14 of 18
@TrevorPH  Just a thought. Would you be able to run perhaps a small diameter flexible tube - effectively a duct - along the route from the external splicing point ( CSP) to where you’d like the ONT to be? If you leave a drawstring in there, all the OR engineer would need to do is pull the fibre through. Making sure of course that any bends are not too sharp. A £2 coin could be used as a rough guide of the minimum bend radius. Others have used hose pipe within hollow walls quite effectively too..
Message 15 of 18
Happy to say, resolved.
Message 16 of 18
@TrevorPH If you could say how it was resolved it may be useful for others who might find themselves in a similar situation.
Message 17 of 18
@TrevorPH  Yes, I'd be interested to know how it was resolved.  (I rather got the impression it was just too awkward for the first guy, so he was making excuses).
Message 18 of 18
Let's just say there was a second engineer and either I was more persuasive or he was more amenable. Or both.
