Message 1 of 3
FTTP install via pole,fibre cable attached to middle of house,I can touch cable from window,not saf
2 REPLIES 2
Message 2 of 3
Re: FTTP install via pole,fibre cable attached to middle of house,I can touch cable from window,not
are you a BT broadband customer?  so you have to open window and stretch out to touch cable so why not safe?  there is no electric power in cable so no possible shock
Message 3 of 3
If I remember right the Low Flying Wires Act says a Drop Cable needs to be at least 2m from a window.
Is it your house/install or for your neighbour?
Probs need to contact Openreach, assuming it’s there’s and not an Alt Net’s to see if it can be moved or raised higher using a Swan Neck or something.
