jonodavies69
Message 11 of 35
Re: FTTP router keeps on dropping out
We've had the ONT changed and tried various Cables from that to the router too. And tried 2 smart hubs and 2 different TP-link( 3rd party) routers to no avail.
The engineer then suggested it could be service provider related.
Message 12 of 35
There could be an issue further up the network, which is causing the loss of connectivity, which I assume is what you are getting?
What are the symptoms, is it just a loss of DNS resolution, and how quickly does it recover?
jonodavies69
Message 13 of 35
The symptoms are :
devices dissconnect, router turns green then orange then comes back to blue.
It takes a good few minutes to come back with the smart hub, on the tp link routers it was faster coming back but i put that down to the router being a different model.
Message 14 of 35
What does the event log show on the home hub, is it loss of PPPoE connection?
jonodavies69
Message 15 of 35
21:28:41, 07 Mar.
ppp0:TR69 ConnectionRequest Failed
21:28:41, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:2, [unknown User-Agent]): Connection: Close
21:28:41, 07 Mar.
ppp0:TR69 ConnectionRequest: processing request from ACS
::, undefined.
7.1.2; AFTN Build/NS6260)
21:28:41, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:3, [unsupported User-Agent]): Accept-Encoding: gzip
::, undefined.
21:28:38, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:3, [unsupported User-Agent]): Connection: Keep-Alive
21:28:36, 07 Mar.
ppp0:TR69 connectivity to (pbthdm.bt.mo) has been closed
21:28:36, 07 Mar.
��<¶:TR69 sending GetParameterValuesResponse message
21:28:36, 07 Mar.
ppp0:TR69 receiving GetParameterValues message
21:28:36, 07 Mar.
:TR69 sending SetParameterValuesResponse message
21:28:36, 07 Mar.
ppp0:TR69 receiving SetParameterValues message
21:28:35, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:2, [unknown User-Agent]): User-Agent: Avast NCC
21:28:35, 07 Mar.
ppp0:TR69 connectivity to (pbthdm.bt.mo) has been initiated
21:28:35, 07 Mar.
ppp0:TR69 receiving InformResponse message
21:28:34, 07 Mar.
ppp0:TR69 event found : 0 BOOTSTRAP
21:28:33, 07 Mar.
ppp0:TR69 sending Inform message
21:28:32, 07 Mar.
21:28:31, 07 Mar.
21:28:30, 07 Mar.
21:28:29, 07 Mar.
ppp0:TR69 creating new session with ACS
21:28:25, 07 Mar.
21:28:23, 07 Mar.
ppp0:TR69 connectivity to (pbthdmw.bt.m) has been closed
21:28:22, 07 Mar.
21:28:22, 07 Mar.
21:28:22, 07 Mar.
21:28:21, 07 Mar.
ppp0:TR69 connectivity to (pbthdmw.bt.m) has been initiated
21:28:21, 07 Mar.
21:28:20, 07 Mar.
ppp0:TR69 event found : 6 CONNECTION REQUEST
21:28:20, 07 Mar.
ppp0:TR69 event found : 4 VALUE CHANGE
21:28:19, 07 Mar.
21:28:19, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:2, [unknown User-Agent]): Accept: */*
21:28:18, 07 Mar.
21:28:18, 07 Mar.
21:28:17, 07 Mar.
21:28:15, 07 Mar.
21:28:14, 07 Mar.
21:28:13, 07 Mar.
21:28:13, 07 Mar.
21:28:13, 07 Mar.
21:28:09, 07 Mar.
21:28:08, 07 Mar.
21:28:08, 07 Mar.
��:TR69 sending SetParameterAttributesResponse message
21:28:08, 07 Mar.
ppp0:TR69 receiving SetParameterAttributes message
21:28:08, 07 Mar.
21:28:08, 07 Mar.
21:28:08, 07 Mar.
21:28:08, 07 Mar.
21:28:08, 07 Mar.
���jF:TR69 sending GetParameterValuesResponse message
21:28:08, 07 Mar.
21:28:08, 07 Mar.
21:28:08, 07 Mar.
21:28:07, 07 Mar.
21:28:07, 07 Mar.
21:28:07, 07 Mar.
21:28:07, 07 Mar.
21:28:07, 07 Mar.
21:28:07, 07 Mar.
21:28:06, 07 Mar.
21:28:06, 07 Mar.
21:28:05, 07 Mar.
21:28:05, 07 Mar.
21:28:04, 07 Mar.
21:28:04, 07 Mar.
21:28:03, 07 Mar.
21:28:02, 07 Mar.
21:28:01, 07 Mar.
21:27:58, 07 Mar.
21:27:58, 07 Mar.
21:27:56, 07 Mar.
:HTTP UserBasic login from 192.168.1.65 successfully
21:27:56, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:2, [unknown User-Agent]): Host: ncc.avast.com
21:27:56, 07 Mar.
wl0:IGMP group 224.0.1.187 on interface wl0 started by 192.168.1.65
21:27:56, 07 Mar.
wl0:IGMP group 224.0.1.187 on interface wl0 by 192.168.1.65 requested
21:27:56, 07 Mar.
wl0:IGMP join received for group 224.0.1.187 on interface wl0
21:27:39, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:2, [unknown User-Agent]): User-Agent: Microsoft NCSI
21:27:39, 07 Mar.
21:27:39, 07 Mar.
BR_LAN:The HTTP headers offered by the device (id:2, [unknown User-Agent]): Host: ip-info.ff.avast.com
21:27:39, 07 Mar.
BR_LAN:The DHCP options that are offered by the device (id:2): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,12,81,60,55 | RequestOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | HostName: BEAST-2 | VendorId: MSFT 5.0
21:27:39, 07 Mar.
:DHCP Confirmation of Request
21:27:37, 07 Mar.
wl0:A WiFi device <0C:8B:FD:74:74:FD> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
21:27:21, 07 Mar.
BR_LAN:A redirect rule is added for the device (id:5)
21:27:21, 07 Mar.
BR_LAN:The OIE is supported for the device (id:5)
21:27:21, 07 Mar.
BR_LAN:The DHCP options that are offered by the device (id:5): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,12,81,60,55 | RequestOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | HostName: Jacys-Laptop | VendorId: MSFT 5.0
21:27:21, 07 Mar.
BR_LAN:A redirect rule is added for the device (id:4)
21:27:21, 07 Mar.
BR_LAN:The OIE is supported for the device (id:4)
21:27:21, 07 Mar.
BR_LAN:The DHCP options that are offered by the device (id:4): DiscoverOptions: 53,61,57,60,12,55 | DiscoverOption55: 1,3,6,15,26,28,51,58,59,43 | RequestOptions: 53,61,50,54,57,60,12,55 | RequestOption55: 1,3,6,15,26,28,51,58,59,43 | HostName: Galaxy-S7-edge | VendorId: android-dhcp-8.0.0
21:27:21, 07 Mar.
21:27:21, 07 Mar.
21:27:14, 07 Mar.
BR_LAN:New device (id:5) connecting on the LAN was detected
21:27:14, 07 Mar.
wl0:Device <0C:8B:FD:74:74:FD> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
21:27:14, 07 Mar.
wl1:A WiFi device <44:1C:A8:7D:C1:2B> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
21:27:07, 07 Mar.
BR_LAN:New device (id:4) connecting on the LAN was detected
21:27:07, 07 Mar.
wl0:A WiFi device <8C:45:00:AD:09:3A> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
21:26:43, 07 Mar.
BR_LAN:A redirect rule is added for the device (id:3)
21:26:43, 07 Mar.
BR_LAN:The OIE is supported for the device (id:3)
21:26:43, 07 Mar.
BR_LAN:The DHCP options that are offered by the device (id:3): DiscoverOptions: 53,61,57,60,12,55 | DiscoverOption55: 1,3,6,15,26,28,51,58,59,43 | RequestOptions: 53,61,50,54,57,60,12,55 | RequestOption55: 1,3,6,15,26,28,51,58,59,43 | HostName: amazon-f5fbe64b9 | VendorId: android-dhcp-7.1.2
21:26:43, 07 Mar.
Hi im not up to speed with this side of things to be honest. does this make more sense to you ? This is from last night
21:26:41, 07 Mar.
ppp0:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
Message 16 of 35
Mostly :TR69 events which are initiated from the BT management end, but there do seem a lot of them.
The question is, what shows on the event log,  just prior to the router disconnect, and why is it only specific devices (Apple) that is causing the issue?
I guess that none of your own devices are Apple?
I do suspect an issue back towards the BT network, but I can see its going to be difficult to diagnose without higher level support from the FTTP team.
jonodavies69
Message 17 of 35
there's 3 apple devices here ,...an older ( 2012 model approx ) ipad that works fine, my daughters iphone 6 plus that's totally unusable and her ipad pro seems to be hit and miss. Just having the iphone turned on in our premises causes issues, even with the wifi on the iphone turned off completely.
awaiting the fttp call this morning so will keep you posted either way 🙂
Message 18 of 35
Without some form of network diagnostics tools, I cannot see how this can be easily resolved.
Message 19 of 35
How close to the FTTP modem,home hub and Ethernet cabling, is the iPhone that causes the problem, could it be the actual mobile transmissions that are getting into the ONT, and causing it to lose connection?
Do you have any other mobile devices which are used in proximity to the ONT?
Maryemm
Message 20 of 35
I find this problem interesting as I have a similar problem.
We have FTTP and when it was first set up I was able to watch a whole film on TV without any trouble. Now my connection constantly drops while we are on line. On my Kindle and iPad there are hiccups which are soon over. On my desktops there is a slight pause and then the action continues. The blue light on my router never falters!!
My set-up is upstairs : our main TV downstairs. Recently we can't watch a 30 minute TV programme on the internet without that awful spinning "wheel" which soon gets unbearable.
I have posted regarding the latter problem elsewhere as I hope using an extender will solve the problem.
However it is "interesting" that someone else has this loss of connection problem. BT have tested my connection and report it as "stable". Before FTTP was installed I had our house telephone set- up checked privately. and all was /is well.
Before the connection drop, next door was "empty," being renovated. Now neighbours are back. Could changing the wireless frequency (is that the word?) on the router help?
