exharris
Message 1 of 2
FTTP run terraced house
Moving into a mid terrace in a few weeks where existing copper line is served from a pole at the rear and a wire goes from that pole to the house and I think the cable runs over the roof to the front and then down and into the front room. I say this because the existing master socket is in the front room.
Ordered Full Fibre and I am assuming the fibre runs from the same pole as the copper? If so, presumably they will run it over the roof again so as to install ONT in the front room...?
does anyone know? I would prefer the ONT in the front room because that’s where TV, boxes etc are. And want them connected by Ethernet
Tags (3)
1 REPLY 1
pippincp
Message 2 of 2
Re: FTTP run terraced house
The install enginerr will advise. Tea/coffe and buscuits may help.
