Octopus16
Message 1 of 10
FTTP upgrade
I've just been told that my area is being upgraded to FTTP, after years of ADSL. What speeds and latency have you been achieving over BT Ultrafast 250?? And what is the hub like??
9 REPLIES 9
imjolly
Message 2 of 10
Re: FTTP upgrade
Are you an existing bt broadband customer?
if so enter your phone number and post results.  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
albertj
Recognised Expert
Message 3 of 10
Re: FTTP upgrade
Hi @Octopus16
Welcome to the Community!
Lucky you! 😊
These cables can support over 1gbps (eventually!) and are being profiled down, you should have no problem getting this kind of speed.
You get the Smart Hub 1 (with WAN Port to support the ONT) if you don't get Complete Wi-Fi, and the Smart Hub 2 if you take out Complete Wi-Fi or Halo 2. Obviously, you will also get the Wi-Fi Disk(s) if you have Complete Wi-Fi. Both work well, albeit a few problems with the SH2 and Smart Home devices, but these can be fixed.
With FTTP you can easily swap it out to your own router if it has a WAN Port.
Thanks,
AJ
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Octopus16
Message 4 of 10
Re: FTTP upgrade
Thanks for replies. Being installed due to business down the road ordering Fibre On Demand, linking us up too.
albertj
Recognised Expert
Message 5 of 10
Re: FTTP upgrade
It's available for you, are you able to place an order?
imjolly
Message 6 of 10
Re: FTTP upgrade
to place an FTTP  order you need to phone FTTP team 08005874787
Starwire
Recognised Expert
Message 7 of 10
Re: FTTP upgrade
Says you can only get 350/50.
The Head End where you are might use ECI Technology as all the Nokia and Huawei sites I work on say the EU’s can get 1000mbps.
Octopus16
Message 8 of 10
Re: FTTP upgrade
It’s quite confusing, really!
I can’t actually place an order with BT, yet!
The reason the fibre was installed is because of a fibre on demand request down the lane, so they’re connected down the lane, but they’ve said we’re being connected on the 2nd February 2020.
Its very interesting because the fibre is connected with an exchange in a city, 10 miles away, and ADSL (current) is fed with a rural exchange, both in different county’s!
This means our new number on 2nd of February will be a different dialling code to my local one!
Our system will be, once installed, capable of 330mbps downlink and 50 uplink. A business package would be 1000mbps! I’m going for 330 probably!
This information was told to me by a local Openreach engineer, while he was completing a site survey.
pippincp
Sage
Message 9 of 10
Re: FTTP upgrade
Not all ISP's who sell fibre are offering 1000Mbps, BT certainly isn't yet.
@Octopus16 As the checker says its available you should be able to order it via BT even though the install is delayed.
Starwire
Recognised Expert
Message 10 of 10
Re: FTTP upgrade
Regardless of whether BT Consumer/Business sell Openreachs 1000mbps Service the Wholesale Checker would show that regardless.
I’ve been working on a over lay site for the past few weeks and have been helping people how to check if they can get it. The BT Wholesale Site says they can all get 1000mbps regardless of what Provider they are currently with.
