Message 1 of 7
FTTP wifi 6 third party router
Hello,
Im having Fibre 900 installed soon and I'd like to get a third party wifi 6 router.
My question is; will I simply be able to plug this router into the ONT (that BT installs) via the WAN port and be up and running?
- There's no need for a modem in between the ONT and the router right?
Thanks for the help!
6 REPLIES 6
Message 2 of 7
Re: FTTP wifi 6 third party router
@f_twentytwo
Welcome to this user forum.
Yes you can, provided you do not have BT Digital Voice.
You will need to enter the correct login details.
Username bthomehub@btbroadband.com
Password BT
No extra modem needed.
Message 3 of 7
@Keith_Beddoe
thankyou for the quick response!
Is digital voice an additional extra? Im getting a landline with pay as you go calls etc which I'll never use.
Message 4 of 7
The landline connection needs the BT Smart Hub 2 to work, unless you already have a working landline phone connection on a phone socket.
Message 5 of 7
@Keith_Beddoe
so if I have no plans of plugging a phone in anywhere, it doesn't make a difference?
Message 6 of 7
@f_twentytwo wrote:
@Keith_Beddoe
That is correct. On an FTTP only connection, BT use the Smart Hub 2 to provide the phone connection.
Message 7 of 7
@Keith_Beddoe
thanks for the help!
let the wifi 6 router shopping begin.
