Message 1 of 5
FULL FIBRE split
If i have BT full fibre installed, could a fibre splitter was added, so 1 smart hub is in the house and 1 smart hub in the garden office  .
I guess i would have to have 2 accounts and have to pay for 2 fibre connections.
Is this possible
4 REPLIES 4
Message 2 of 5
Re: FULL FIBRE split
You can split a fibre like you can Coax.
You’d either have to get a second fibre circuit installed or just run and Ethernet Cable to your Man Cave in the Garden and use a second hub as an access point.
Message 3 of 5
Hi,
i would prefer 2 seperate fibre lines, so  do you think  BT can supply me with this system through the customer service
Message 4 of 5
Just order a second line.
Message 5 of 5
They can supply you with a second line but you would be liable for any Network Construction Costs for it as they’re only legally obliged to provide you with one.
