puppykins
Message 1 of 23
Faceplate
Hi. My broadband has been cutting out a few times daily and I can't make or receive phone calls - when I try making a call I get a loud noise like a revving motorbike. It's the same with other phones I've tried.
As advised, I unscrewed the faceplate to use the test socket, but there were a tangle of wires there and I didn't want to dislodge anything so I screwed the plate back on and a second or two after this, I noticed my BT hub light showing yellow for a minute or so before turning blue again. It did this on the two occasions I tried unscrewing the plate. I'm worried that this means there's a fault in the faceplate wiring and that I'll face huge charges for the call out plus electrician's fees.
Help!!
22 REPLIES 22
imjolly
Message 2 of 23
Re: Faceplate
why do you think you will need electrician?  is the socket multi purpose - phone and aerial for tv and power socket?
post pic of socket would help  if problem on your side of test socket then more than like get charged callout £85
puppykins
Message 3 of 23
Re: Faceplate
It's just for my phone and broadband.
Can't upload a photo unfortunately, but thanks for your reply.
imjolly
Message 4 of 23
Re: Faceplate
if it is just for your phone and broadband then no electrician is need
try connecting to test socket as any wires connected to the front plate are customers responsibility anyway and see if that works ok
puppykins
Message 5 of 23
Re: Faceplate
puppykins
Message 6 of 23
Re: Faceplate
I'm frightened I might accidentally dislodge something as it's all a tangled mass of wires!!
Keith_Beddoe
Message 7 of 23
Re: Faceplate
That reminds me of an old phone/analogue modem splitter, not a microfilter, are you sure that plug in unit is suitable for broadband?
Keith_Beddoe
Message 8 of 23
Re: Faceplate
There should only have been two wires connected, unless of course you have other sockets elsewhere. They could easly cause disconnections.
 I would be inclined to unplug that splitter, and use a microfilter if you have one.
imjolly
Message 9 of 23
Re: Faceplate
wow  long time since I seen one of these splitters
puppykins
Message 10 of 23
Re: Faceplate
It was actually a friend who helped set up my broadband connection years ago. I've had no trouble until now!!
