Message 11 of 23
Re: Faceplate
it may be you splitter has given up after all this time  surprised it has lasted this long  maybe your connection will improve when you use a proper filter
Expert
Message 12 of 23
Re: Faceplate
@puppykins
There is no test socket behind there.
Any of the sockets look like this?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 13 of 23
Re: Faceplate
@puppykins wrote:
It was actually a friend who helped set up my broadband connection years ago. I've had no trouble until now!!
Do you have a microfilter you can use instead, if so unplug that splitter, and plug the microfilter in.
BT ADSL Micro Filter RS
Message 14 of 23
Re: Faceplate
Yes that's how it looks.
Message 15 of 23
Re: Faceplate
I don't have one unfortunately. Must buy one. Pity I arranged for an engineer to call though!!!
Message 16 of 23
Re: Faceplate
your phone socket is not same as does not have split front face   you should have received a filter when you got you hub
if it is the splitter that is causing your problems then you will probably be charged £85 for engineer visit
Message 17 of 23
Re: Faceplate
The engineer is supposed to call me within the next few days to arrange a visit. Would you advise me to cancel and try the microfilter first? Jeez, if only I'd come on here first!
Sage
Message 18 of 23
Re: Faceplate
That is not just a splitter. It is also a filter however it's that old (I haven't seen one for over 10 yrs) It's almost guaranteed to have failed.
Message 19 of 23
Re: Faceplate
Just ordered a microfilter on Amazon. Praying it works.Smiley Embarassed
Moderator
Moderator
Message 20 of 23
Re: Faceplate
@puppykins You would have been sent a couple of filters with your Home Hub. Do you still have the box it came in?
