Message 1 of 12
Faster bb keeps dropping
Hi I have faster bb which is infinty below 24mps. I am having an issue bb keeps dropping but the blue light stays on my hub of for about 45 seconds. this is on a wired connection and wireless devices and all drop the same time. I have been sent a home hub 6 and still happening I have changed all of the internal cables to the master but not the master I do no what I am doing as I am a engineer for a differnet company and can't there service where I live but that's a different story. Called bt support and they test the line no issues can't hear any noise on the line but when I check the router logs I see that the hub loses its ppoee connection and trys to reconncet and it does and then I am back online. I want to get an engineer to check out there side as i can only see it being that but 129.99 just incase it's not is a joke. Anyone got any ideas.
11 REPLIES 11
Sage
Message 2 of 12
Re: Faster bb keeps dropping
Does this still happen when connected directly to the test socket?
Message 3 of 12
master looks like this and i am unable to test in test port as i dont have a micro filter https://www.bing.com/images/search?view=detailV2&ccid=66JQQTSj&id=3B4EDC9323D407D622811367D52407D60B...
i did notice this in the logs
 dsl:VDSL link Up: Down Rate=16006Kbps, Up Rate=1185Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
snr margin down 0db
this good on infinty.
Sage
Message 4 of 12
A microfilter will cost less than £129.99.
When we ask you to connect to the test socket it is to rule out any of your internal wiring therefore avoiding the charge.
Can you not ask a friend if they have a spare one? I've collected 8 over the years of using broadband and probably thrown away more than that.Smiley Very Happy
AS you know how to access the logs can you get the full connection details? On the HH% it's in troubleshooting/helpdesk. Lines 1 - 12 will suffice.
Message 5 of 12
06:23:05, 17 Jun.:WAN: SENSING AUTO VDSL06:22:27, 17 Jun.ptm0.101:VLAN VLAN_DATA connected
06:22:27, 17 Jun.:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT
]06:22:27, 17 Jun.:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
06:22:27, 17 Jun.dsl:VDSL link Up: Down Rate=16006Kbps, Up Rate=1185Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
06:22:11, 17 Jun.:VLAN VLAN_DATA disconnected
06:22:03, 17 Jun.dsl:VDSL Link Down: duration was 21915 seconds
00:17:26, 17 Jun.:WAN: SENSING AUTO VDSL00:16:49, 17 Jun.ptm0.101:VLAN VLAN_DATA connected
00:16:49, 17 Jun.:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:16:49, 17 Jun.:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT
theres the wan logs
getting micro filter today
let me no if you want any different logs
Message 6 of 12
can you post the help desk page in your hub
Message 7 of 12
Product name:
BT Hub 6A
Serial number:
+084316+NQ64517969
Firmware version:
SG4B10002244
Firmware updated:
16-Jun-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 7 Hours 24 Minutes 29 Seconds
Data rate:
1.19 kbps / 16.10 kbps
Maximum data rate:
1185 / 16006
Noise margin:
6.4 / 3.3
Line attenuation:
34.8
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
156 MB Uploaded / 3530 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-M278
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-M278
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:5E:5B:67
Software variant:
Boot loader:
7.33.1
belive this is it home hub 6
Message 8 of 12
bump
Message 9 of 12
Version:1.0 StartHTML:000000272 EndHTML:000021725 StartFragment:000020414 EndFragment:000021510 StartSelection:000020414 EndSelection:000021506 SourceURL:https://community.bt.com/t5/BT-Infinity-Speed-Connection/Faster-bb-keeps-dropping/m-p/1754571/highli... bb keeps dropping - BTCare Community Forums BT.com
Product name:
BT Hub 6A
Serial number:
+084316+NQ64517969
Firmware version:
SG4B10002244
Firmware updated:
16-Jun-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
Data rate:
Maximum data rate:
1185 / 16006
Noise margin:
6.4 / 3.3
Line attenuation:
34.8
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Broadband username:
BT Wi-fi:
Active
BTHub6-M278
Smart (Channel 11)
BTHub6-M278
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:5E:5B:67
Software variant:
Boot loader:
7.33.1
Moderator
Moderator
Message 10 of 12
Have you managed to connect with a new filter @Ken1991.
Cheers
David
