Bbop
Message 1 of 5
Fastpath
Trying to reduce my pings/latency.  How can I check or request to have FastPath enabled on my account?
I spoke to BT technical and the guy said he'd worked there for ages and never heard of it. He called through to connections but they said they couldn't help. He said best place to ask is on the community board (where I can see some of the helpful mods have switched on FastPath for some customers). Many thanks.
Tags (3)
4 REPLIES 4
imjolly
Message 2 of 5
Re: Fastpath
are you sure it was fibre connection where mods change lateny fast as I suspect you were reading copper/adsl connection post where mods could change latency - not fibre
Bbop
Message 3 of 5
Re: Fastpath
That was the one thing I was wondering about. Tech and connections team didn't know and said here was place to ask. So maybe it's not relevant...
NeilO
Moderator
Moderator
Message 4 of 5
Re: Fastpath
@Bbop I'm afraid  fastpath is not an option we can choose for FTTC connections. The default option is set to Automatic and DLM will decide which interleaving option is best suited for your line.
Bbop
Message 5 of 5
Re: Fastpath
Thanks for letting me know.
For anyone else interested in this topic here's the useful info (didn't locate this page until after raising query)
http://bt.custhelp.com/app/answers/detail/a_id/8547/~/what-is-interleaving%3F-what-are-its-pros-and-...
