JohnC2
Moderator
Moderator
Message 11 of 21
Re: Fault reported online (broadband speed), engineer booked. BT cancelled the appointment, faulty s
Hi @silentflyer Please can you check as your connection should now be improving. Post back and let me know how you get on.
Cheers
John
silentflyer
Message 12 of 21
Thanks @JohnC2 , I noticed connection reset on 24th and:
FireShot Capture 095 - OpenWrt - Overview - LuCI - http___192.168.1.1_cgi-bin_luci_.jpg
Appears stable, hopefully DLM might try reducing snr to boost further the data rate in the coming weeks.
Thanks so much.
pippincp
Message 13 of 21
7Mb is going to be a world of difference. I wonder what you are going to do with that extra 7Mb? **Edited**
Mustafa_Islam
Message 14 of 21
Bro why u being so rude? 7mbps is almost a whole 1MB increase in download. If that reduces the download time by even 10 minutes of anything he’s downloading it’s worth it.
____________________________
If I helped out then leave my reply a Kudos by clicking the thumbs up button
silentflyer
Message 15 of 21
@JohnC2  Connection has been stable and unchanged for 5 weeks showing the following:ss.jpg
Is there any reason the line doesn't train to nearer the max attainable rate?
imjolly
Message 16 of 21
which exchange and cab are you on - you deleted from dslchecker
your speed/attainable has improved with last reset from that posted on 26/8
silentflyer
Message 17 of 21
Aysgarth CAB 3, does that make a difference?
Stats at 06/09 had improved to,
Data Rate   73.39 Mb/s   / 19.999 Mb/s
Max Data Rate   76.732 Mb/s  / 24.492 Mb/s
LATN             9 db / 7 db
SATN              9 db / 7 db
SNR                4db / 15db
Its remained very similar ever since.
I interpreted this is a drop in the target snr from 6db downwards,  but this hasn't resulted in an increase in the actual data rate but  increased the snr of the upstream.  Just seems a bit odd, like its still locked.
imjolly
Message 18 of 21
cab makes a difference in that Huawei can get G.INP and ECI cannot at present - you are on Huawei
silentflyer
Message 19 of 21
Any idea why the line might not be training to nearer the maximum speed?
Todays stats:
FireShot Capture 111 - OpenWrt - Overview - LuCI - http___192.168.1.1_cgi-bin_luci_.jpg
imjolly
Message 20 of 21
your noise margin is about normal so hopefully if line remains stable the G.INP will kick in with noise margin going to about 3db with a speed increase
