Recognised Expert
Message 1 of 24
Faulty faceplate?
Hi
If I have a faulty faceplate - as supplied by openreach a few years ago, would this be replaced free of charge?
(asking on behalf of some relatives)
From: https://community.bt.com/t5/BT-Infinity-Speed-Connection/Openreach-master-socket-MK1-or-MK2/td-p/123...
It seems to be the first one.
Symptoms are:
crackling phone line - sometimes very bad
bb dropping a number of times a day
BT have got them to remove only the lower part of the faceplate and connect the phone to the test socket and after taking a little while to settle it now works fine, without any crackling.
The BB is still connected to the upper part of the faceplate and it still disconnects a number of times a day.
There is no extension wiring behind the master socket.
thanks!
23 REPLIES 23
Message 2 of 24
Re: Faulty faceplate?
Have you tried using a filter in test socket then connect both router and phone to filter in test socket and see if that improves thingsg
Recognised Expert
Message 3 of 24
Hi
I had thought of getting them to do that but I don't think they have a microfilter to hand - I'm just providing remote support!
I'm going to send them a couple of microfilters.
I think they have Openreach due out in a day or so - hopefully to replace the faceplate. It does sound like a faulty faceplate, yes?
Sage
Message 4 of 24
No, it sounds like a noisey line fault which will cause the internet to drop.
Recognised Expert
Message 5 of 24
Filtered faceplates can sometimes be faulty & sometimes it is more reliable to use an ordinary NTE5A + a dangler.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Distinguished Guru
Message 6 of 24
Front plates very rarely go faulty.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Recognised Expert
Message 7 of 24
Mine did straight away! Maybe not "go" but more like "come" Smiley Wink.
Recognised Expert
Message 8 of 24
I think @Keith_Beddoe indicated that these split front plates can become faulty...
Message 9 of 24
They can go faulty but not a regular thing
Message 10 of 24
It usually happens after a storm, internal active components break down, as they are far too complex.
This is a much simpler device with only passive components.
LINDY VDSL2 Microfilter Faceplate
