Telecom89
Recognised Expert
Message 11 of 24
Re: Faulty faceplate?
@Keith_Beddoe wrote:
@Telecom89 wrote:
I think @Keith_Beddoe indicated that these split front plates can become faulty...
It usually happens after a storm, internal active components break down, as they are far too complex.
This is a much simpler device with only passive components.
LINDY VDSL2 Microfilter Faceplate
Thanks. If I go down this route is this just a plug and play replacement for their original split faceplate, without any cable changes etc. being required? They don't have any extension cabling from the master socket.
Message 12 of 24
If there are no extensions then yes should just replace the existing socket front
Distinguished Guru
Distinguished Guru
Message 13 of 24
Although @Keith_Beddoe is quite correct he is (IMHO) referring to lightening storms which may cause a surge on the line.
You've already been suppplied the best advice, try a quiet line test on 17070 option 2 with (preferrably) a corded phone.
If the line noise is still evident you have a line fault which should be reported as such on 151, not a broaband one.
If the line has a problem then so will your broadband.
Telecom89
Recognised Expert
Message 14 of 24
Hi - the trouble is that they have an intermittent fault and whenever BT contact them it seems to be ok. I'll get them to run a quiet line test a few times and see what happens. They said that there's been work ongoing on a nearby green cabinet. Could that be the issue?
Telecom89
Recognised Expert
Message 15 of 24
Ok - sometimes the quiet line test is quiet, othertimes persistent crackle on line.
BT seem particularly poor at dealing with intermittent faults. They've already had a HomeHub replaced which made no difference to their BB disconnecting. Under what circumstances would customers be charged the fee of about £130?
Message 16 of 24
If the problem was due to their internal wiring.
If there is crackling when connected to the test socket there will be no charge.
Telecom89
Recognised Expert
Message 17 of 24
Thanks. I'll let them know. As a matter of interest, what would be causing an intermittent crackle on the line?
Message 18 of 24
A corroded joint probably.
XRaySpeX
Recognised Expert
Message 19 of 24
It's worth having a read of Why do I need a landline phone?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 20 of 24
I notice that you often use links to forum member Keith Beddoe's very useful webpages. Perhaps it would be nice to acknowledge that it was Keith who compiled the pages when you post links to them so that credit can be given for his work.
