Message 1 of 15
Fibre 1 (FTTC) - Telephone problem?
Hello,
Today I was upgraded from "Broadband Unlimited" to "Fibre 1".
It seems to work, however the engineer told me that the internet is OK,
but that there is a fault when telephone is connected, and this could degrade the performance.
Please see the image for my setup. I can't see a problem. What do you think? Thanks!
14 REPLIES 14
Message 2 of 15
Re: Fibre 1 (FTTC) - Telephone problem?
that looks ok  do you hear any noise if you dial 17070 option 2?
Message 3 of 15
Thanks for your answer.
I tried 17070 option 2 and I would say it is quite quiet.
Very faintly in the background I hear a deeper tone, which is periodically interrupted
by a higher tone, but all this can barely be heard.
Message 4 of 15
with a corded phone it should be silent and any noise can be a problem  with a cordless then a dull hum is often heard
Message 5 of 15
As shown on the image both are corded phones.
I made the test with phone 1, now I also made it with phone 2.
On phone 1 (connected with 5m cable), as mentioned, I can hear this very, very low sound – only when I press the handset against my ear!
On phone 2 (connected with 2m cable) I can hear absolutely nothing.
I assume that what I hear on phone 1 is some crossfeed from other (computer) cables which are located near the phone cable, so I don't think it's something coming via the phone socket. The fact that phone 2 is totally silent confirms this.
So why could the engineer have seen a fault when telephone had been connected...?
Message 6 of 15
Have you tried changing the filter? How is this fault manifesting itself in day to day usage?
Message 7 of 15
Thanks for asking back.
Nothing has ever been manifesting in day to day usage under "Broadband Unlimited".
It's just that the engineer said today, that he gets a "fault" displayed when telephone is connected.
I didn't change anything, both phones worked (and work) fine on an original BT filter.
This is weird...
Message 8 of 15
 please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
see if new stats look ok
Message 9 of 15
Thank you, here is the information from the SH2, not sure what to look for...
This is a list of your BT Smart Hub settings and current statistics.
Product code:Smart Hub 2
Serial number:+091301+1949050113
Firmware version:v0.17.01.12301-BT
Firmware updated:Thu May 28 04:55:29 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,06 Hours12 Mins56 Secs
Data rate:9.995 Mbps / 54.998 Mbps
Maximum data rate:16.929 Mbps / 85.237 Mbps
Noise margin:9.7 / 10.7
Line attenuation:9.0 / 16.7
Signal attenuation:8.8 / 15.9
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:177.0 MB Uploaded  / 7.6 GB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated [this is not true – Status page says Not active]
2.4 GHz wireless network name:BT-XPACGR
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-XPACGR
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:0C:8E:29:A1:07:C0
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
...and from the website:
Message 10 of 15
You don't have a problem.
