Message 1 of 6
Fibre 2 FTTC with limited speeds
Hi all.. long story short - ceased previously and have since come back to by. Was on 80/20 service and getting around 60mb plus.
what I don't understand now is that despite the attainable stats looking ok and being on fibre 2 I am only getting 55 down and 10 up - it's like the profile is locked low.
spoke to BT and they weren't sure of the issues.. likewise a new order on address is showing 80/20 being available.
any ideas on how I could resolve this? Stats as follows.
thanks
Firmware version:v0.31.00.10253-BT
Firmware updated:Tue Feb 1 01:36:24 2022
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:0 days,04 Hours00 Mins31 Secs
Data rate:9.995 Mbps / 54.998 Mbps
Maximum data rate:23.066 Mbps / 72.160 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:15.3 / 7.0
Line attenuation:5.0 / 14.8
Signal attenuation:5.1 / 16.4
VLAN id:101
Upstream error control:Off
Downstream error control:Off
5 REPLIES 5
Message 2 of 6
Re: Fibre 2 FTTC with limited speeds
You would appear to be on the Fibre 1 product and not Fibre 2.
Check what your product is showing in your MyBT and thereafter contact BT and report the problem.
Message 3 of 6
You've been provisioned at Fibre1 rather than Fibre 2. Speak to customer services and point out the error of their ways.
Message 4 of 6
Thanks for the reply. That was what I suspected - it's just getting through to someone who knows how to fix it ... haven't had much luck so far. 
Message 5 of 6
Hi @nostra999 and welcome back.
Good to see you again. If the customer service guys can't sort this out for you I'll be happy to take a look. I'll drop you a private message now so you can get in touch if you need to.
Cheers
David
Message 6 of 6
Hi @nostra999,
Thank you for taking my call today. I was happy to hear that you have noticed an increase after your profile was increased to 80/20.
If you need anything else or have any questions, please feel free to drop us a reply.
Thanks,
Paddy
