Message 1 of 12
Fibre 2 correct profile speeds
Hi, After countless talks with BT on the phone and explaining to them that i was on the wrong profile and capped at 55/10 the mod team on here helped me get the correct profile set (THANK GOD)
The only question i have is will my speed increase now? Seems to be stuck at 61.063Mbps when the Max attainable seems to only be going up, It's currently at 73Mbps atm. Any help would be greatly appreciated, Thanks!
1zqjpiD
11 REPLIES 11
Message 2 of 12
Re: Fibre 2 correct profile speeds
As you have only been connected for less than 2 days after reset then just need to stay connected and if on Huawei then you should get a speed boost after 7/10 from G.INP.
You probably are within your expected speed range currenntly
Message 3 of 12
Ah okay thanks, Not sure what make my cabinet is to be honest.
My whole situation was because i was given fibre 1 instead of fibre 2 and my expected speeds /  stayfast guarantee hasn't changed, Although i did contact them asking if it could be changed and they told me it "should" change within the next 24/48 hours
Fingers crossed it does haha
Message 4 of 12
If you enter your phone number your exchange and cab will be shown.  Just post when you can.
Message 5 of 12
Currently have BT without a phone service so can only do address, I'm pretty sure by the looks of the DSL checker its not one with G.INP sadly 😞
8bHzNYg
Message 6 of 12
The dslchecke does not tell you so can your post exchange and cab which was you have deleted
Message 7 of 12
Oh sorry about that, do you need the address also? or is this bit okay?
eNLdS1b
Message 8 of 12
Unfortunately like me you are on an ECI cab so no G.INP boost
Message 9 of 12
Ah okay, Thank you very much for checking for me.
Message 10 of 12
@imjolly Sorry one last question, So since my cabinet doesn't have G.INP does that mean my speeds won't go up close to the max data rate in my stats? or is it a wait and see type of game?
Thanks a lot Jolly.
