mattkyle
Message 1 of 4
Fibre 900 Speeds
Hi there,
I just got Fibre 900 activated today.
Is there any steps I need to take to get the full speeds? I'm currently getting max 350mb on WiFi and 500 on wired. However both speeds seem very sparadic.
I've seen a few posts suggesting a factory reset? Is there anything else I need to consider?
Thanks in advance.
3 REPLIES 3
mattkyle
Message 2 of 4
Re: Fibre 900 Speeds
I've turned the smart hub 2 and the internal openreach router where the fibre enters the house for 10 minutes.
I'm not getting speeds above 400mbs currently.
Is there any other steps I need to perform?
exharris
Message 3 of 4
I’ve ordered this product too and am interested to know how you get on here as I have concerns about speeds.
Has the speed stabilised or improved since this was posted?
mattkyle
Message 4 of 4
I've not seen any improvement on wifi and little improvement on ethernet vs 250 at this stage. I am trying to avoid ringing as I know they are busy but this is likely my next step if I've got no response on here.
