_W4rz_
Message 1 of 6
Fibre Broadband Drop-outs.
Hi People hoping to get some advice and help as Im at the end of my tether with this one.
The issue I have been having has been going on for months, but recently has got very much worse recently
I have been have constant broadband dropout total random around 5 or 6 times a day, I have been in touch with BT and they the normal thing check NTE and run there tests by which they say on the phone that there is an intermittent fault, probable a corroded joint, engineer came out on the 16th of this month and also the 23rd they could not find a fault on the PTQ test he checked the pole and above joints no success.
To sum up where do I stand because in the engineers words when they run there tests if the fault does not present its self there is nothing they can do, surely this is not right need some advise because if I ring them they are just going to send another engineer out and its going to be the same again.
Regards
PS all internal issues have been ruled out. Thanks people.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Fibre Broadband Drop-outs.
Post hub stats. If hh5 then troubleshooting then helpdesk. If hh6 then advanced settings then technical log information
enter phone number and post results. https://www.broadbandchecker.btwholesale.com/#/ADSL
Are you currently using test socket with filter to eliminate faceplate even if filtered and any internal wiring problems
did you check quiet line test?
*edited after @pippincp post
pippincp
Sage
Message 3 of 6
@imjollypostproduction???
imjolly
Message 4 of 6
Post hub stats is what it was  supposed to say
_W4rz_
Message 5 of 6
Product name:
BT Hub 6A
Serial number:
+084316+NQ72431698
Firmware version:
SG4B1000E020
Firmware updated:
20-Apr-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 0 Hours 29 Minutes 28 Seconds
Data rate:
7.32 Mbps / 28.31 Mbps
Maximum data rate:
7322 / 38278
Noise margin:
6.6 dB / 8.2 dB
Line attenuation:
37.1 dB
Signal attenuation:
23.9 dB / 37.1 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
20 MB Uploaded / 15 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-G5S7
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-G5S7-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
B8:EE:0E:B4:8F:19
Software variant:
Boot loader:
7.33.1
Thanks for reply
pippincp
Sage
Message 6 of 6
Try a quiet line test on 17070 option 2 best with corded phone.
