elliottlock1985
Message 1 of 4
Fibre Broadband High Latency
Hi,
I have high latency on my line during bufferbloat, how can this be fixed?
3 REPLIES 3
Message 2 of 4
Re: Fibre Broadband High Latency
Are you using Ethernet or wireless?
post stats from your router
try quiet line test dial 17070 option 2 should be quiet and best with corded phone
elliottlock1985
Message 3 of 4
"Are you using Ethernet or wireless?"
Ethernet
"post stats from your router"
My router is not a standard BT HomeHub, it is a Asus RT-AC5300.
"try quiet line test dial 17070 option 2 should be quiet and best with corded phone"
Using a corded phone it is not quiet/silent. It has an intermittent crackle.
Distinguished Guru
Distinguished Guru
Message 4 of 4
Report a line fault on 151.
