ChoobDriver
Message 31 of 54
Re: Fibre Broadband Outages - Help Needed
So far I have:
bought new Smart Hub and cables,
engineer ok'd cable from external drop wire junction to master socket.
engineer changed master socket for Openreach Mk4
so it's fair to say the problem is external and Openreach's
it is breezy today and the crackling heard on the queit line test kind of cycles between awful and moderate. I still suspect the drop wire as I have for years. I did voice that to the engineer but was dismissed.
BT have requested the engineer check tge drop wire at the pole on Tuesday but he won't do that as and i've no idea what this means but he said it was a 'D' pole so couldn't climb it.
thank you so much for your help you wonderful guys and girls.
Keith_Beddoe
Message 32 of 54
"D" = Decayed pole, not safe to climb, so they have to use an elevating platform instead, which can take a while to organise.
ChoobDriver
Message 33 of 54
Thanks for the info. Wouldn't want anyone risk life or limb for broadband. I'll wait for the engineer to come who will organise the rest I guess
Keith_Beddoe
Message 34 of 54
If the pole is badly decayed,then its probably only the dropwires to the houses that is keeping it up.
ChoobDriver
Message 35 of 54
ChoobDriver
Message 36 of 54
So yesterday the noise on my line was truly awful.
today, silent!
that isn't gonna help the BT Engineer diagnose the fault tomorrow
Keith_Beddoe
Message 37 of 54
today, silent!
They are going to have to check the connections to the DP at the top of the pole, an probably change the dropwire as well, assuming they are bringing a hoist.
ChoobDriver
Message 38 of 54
I completely agree however I doubt there will be a hoist tomorrow. I will update when I know.
i totally appreciate everyone's help and advice. Thank you all
ChoobDriver
Message 39 of 54
Not had an update or visit from engineer so I had a short online chat with BT. The online operator contacted Openreach who says an engineer is in the exchange and has found a fault. He may ir may not need to visit my premises.
My suspicion is still the drop wire but I shall wait and see. No idea if they even contact one with an update or not.
ChoobDriver
Message 40 of 54
So the engineer arrived and it seems the information I was given during the online chat was politely put a complete fib.
waiting on a hoist to install a new drop wire right now.
