ChoobDriver
Message 51 of 54
Re: Fibre Broadband Outages - Help Needed
I believe Kensal Green Exchange, Cabinet 4 but will double check when home
ChoobDriver
Message 52 of 54
Checked. Exchange and cabinet is as per last post
imjolly
Message 53 of 54
you are on Huawei cab so if you maintain a stable connection for 7/10 days then DLM should activate G.INP which should reduce noise margin and give you a bit more speed
ChoobDriver
Message 54 of 54
Thank you @imjolly
