IBanksy
Message 1 of 11
Fibre Broadband (VDSL) network uptime dropping
Is it normal for the network uptime to reset every 1 or 2 days. We've been having unstable pings so wondering if its related? We had an engineer out who improved the speeds which is awesome but surely the network uptime shouldn't keep dropping like this? Does this show something is wrong?
Network uptime:
0 Days, 12 Hours 36 Minutes
System uptime:
3 Days, 22 Hours 27 Minutes
10 REPLIES 10
Message 2 of 11
Re: Fibre Broadband (VDSL) network uptime dropping
That shows you powered down hub 3 days ago but lost internet connection as recent as 12 hrs ago
post stats from hub. If hh6 then advanced settings then technical log information
try dialing 17070 option 2 should be silent and best with corded phone
IBanksy
Message 3 of 11
Yeah that was the engineer. The internet connection loses connection every 24 hours to 48 hours at max.
Product code:Smart Hub 2
Serial number:+091298+1833001810
Firmware version:v0.11.00.09070-BT
Firmware updated:Thu Jan 10 15:10:07 2019
Board version:R01
GUI version:1.53a 29_08_2018
DSL uptime:0 days,12 Hours55 Mins26 Secs
Data rate:19.29 Mbps / 73.445 Mbps
Maximum data rate:19.290 Mbps / 74.197 Mbps
Noise margin:5.9 / 5.1
Line attenuation:24.4 / 33.6
Signal attenuation:23.8 / 35.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:611.9 MB Uploaded / 18.1 GB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-N3A2QN
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-N3A2QN
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommanded)
Wireless mode:Mode 1
Firewall:On
Is this what you want? @imjolly or the event log when the router lost connection.
Message 4 of 11
No.  That's the stats I was looking for
the stats look odd - you have 73mb connection speed but your attenuation is far to high at 33db for that sort of speed
have you tried a factory reset of hub to see if that fixes it?
any line noise?
IBanksy
Message 5 of 11
This is a brand new router. (Smart hub 2) We were having line drops with the smart hub 1 and our contracted ended so we just upgraded because we thought the router was faulty and the new contract came with a new one. I haven't got a phone to test the line. I'll order one @imjolly what exactly is attenuation
Distinguished Expert
Message 6 of 11
@imjolly,
Just to add a comment: I installed a new Smart Hub 2 yesterday.
The line attenuation, as displayed, is 23db downstream, in comparison with the HH6, which was 17db.
This seems odd, but it makes you wonder how accurate the measurement, or estimate, is.
There are no disconnects so far.....,,
IBanksy
Message 7 of 11
@imjolly Do I need an engineer to fix the attenuation? I looked up what attenuation is but it doesn't look like something I can fix myself. Would that explain my unstable line (latency)?
Message 8 of 11
@Ribblelancs
That's interesting about your attenuation. I was involved in testing and initially had higher than 'normal' attenuation but subsequently had a firmware update which now shows my 'normal' attenuation
@IBanksy
There is nothing you or engineer can do to change attenuation as that is calculated by hub. It is not cause of drops in connection
quiet line test?
Message 9 of 11
@imjolly,
Further to my comment, posted previously.
A new Smart Hub2 firmware was installed today, 49hours after initial setup.
The current firmware is at V0.12.02.11078-BT.
GUI firmare remains as it is.
upstream/downstream line attenuation is now shown as 10.4db/16.7db, as against the previous stated levels of 22.8db/30.5db. The new levels are now inline with the previous HH6 stated levels.
Perhaps this may help others, as there appear to be many views on this topic.
VDSL2 speed is 12.2mbps up, 60mbps down, with noise margins of 6.1/3.1 db, which is the normal speed here.
I can now proceed with setting up the disc.
Message 10 of 11
@Ribblelancs
That's the same firmware I am using now which I have had for couple of months - working without problem
