cymrobach1
Message 1 of 14
Fibre Broadband low speed in evening
For the last 10 days have had very low speeds from around 7.30 pm.  Had similar problems back in April after joining in March but speed went back to normal after mod from here got involved and sorted it out with the exchange. I would be grateful if a mod or someone else could look at these stats. It impossible to watch netflix or for children to listen to spotify or play games due to low speeds.
ThanksTest Results 2018-08-22 22.38.15.pngAvailability Checker 2018-08-22 22.47.18.pngHub Info 2018-08-22 22.53.22.png
13 REPLIES 13
Moderator
Moderator
Message 2 of 14
Re: Fibre Broadband low speed in evening
Hi @cymrobach1,
I'm sorry you're seeing a slow down during peak times. I've had a look an I'm not seeing any know issues at your exchange. To get this investigated, I'll need to run a few more checks on your line.
Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
cymrobach1
Message 3 of 14
Thanks for replying. In work at the moment, will send details over late afternoon.
cymrobach1
Message 4 of 14
Contact made via message
Moderator
Moderator
Message 5 of 14
Hi @cymrobach1 Thanks for sending over your details and I'm really sorry to see that your connection is running slowly in the evenings.
I tried calling there but I missed you, I've ran a few checks and I can confirm that the SVLAN that your broadband connection goes through is currently affected by congestion. This has been acknowledged by BT Wholesale and they have plans in place in increase capacity on the 21/09/18.  I will see if Wholesale can do anything to temporarily resolve this in the meantime but I won't have any updates for you until Wednesday due to the bank holiday weekend.
Community ModeratorNeilO
Kudos”
cymrobach1
Message 6 of 14
Hi Neil. Just missed your call. I would be grateful if this could be sorted as last night the download speed dropped to 7.5 which is unacceptable and makes it impossible for our household to watch things at the same time
Distinguished Guru
Distinguished Guru
Message 7 of 14
As @NeilO has stated he will contact BTWholesale to try and get you moved to a less congested SVLAN at the exchange.
With it being a bank holiday weekend nothing can be done until Tuesday at the earliest. He will get your sorted as soon as possible though.
cymrobach1
Message 8 of 14
Hi. I was not having a pop at Neil and hope it didn't come across that way.
Distinguished Guru
Distinguished Guru
Message 9 of 14
It didn't so don't worry. He will get you sorted ASAP.
Moderator
Moderator
Message 10 of 14
@cymrobach1 Sorry about the delay getting back to you, I called there but missed you. I was calling to let you know that BT Wholesale have made arrangements to move your connection to a SVLAN that's not congested. This should happen overnight and I hope that it will resolve the connection speed problems you are experiencing.
Can you do another speed test tomorrow evening and post the results?
Kudos”
