keels24
Message 1 of 12
Fibre Broadband
hello just wanting some advice if possible.
I had a few issues with my broadband dropping connection and have had 3 engineers out so far.  Last time was last Thursday who moved me over to a new fibre line and so far my router has not dropped connection as far as I can see.  I will post my stats below.  Do I need to wait the 10 days for my speeds to increase, as before I had this issue I was getting a constant speed of around 60mbps now getting 40 or below.  Someone said I may have been moved on to a banded profile whatever that is with the issues I was having before , can someone have a look and advise please.
Product name:
BT Hub 6A
Serial number:
+084316+NQ65042542
Firmware version:
SG4B1000E020
Firmware updated:
10-Aug-2019
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
2 Days, 21 Hours 11 Minutes 2 Seconds
Data rate:
13.70 Mbps / 45.23 Mbps
Maximum data rate:
13700 / 54520
Noise margin:
6.2 dB / 6.1 dB
Line attenuation:
40.3 dB
Signal attenuation:
26.5 dB / 40.3 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
192 GB Uploaded / 98 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-5HTS
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-5HTS
5 GHz wireless channel:
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
Keels
11 REPLIES 11
pippincp
Message 2 of 12
Re: Fibre Broadband
Just maintain a stable connection (no reboots of hub) and G.INP should kick in and give you a speed boost.
keels24
Message 3 of 12
Re: Fibre Broadband
Thank you for the response I will be patient and wait 🙂
Keels
Gary_C
Expert
Message 4 of 12
Re: Fibre Broadband
@pippincp out of interest, how can you tell G.INP is available for this line ?
imjolly
Message 5 of 12
Re: Fibre Broadband
you can see the exchange and cab number from the dslchecker results then use codelook to see cab type
keels24
Message 6 of 12
Any help please.
Over days ago I had some issues with my internet dropping out and my speed dropped.  Before this is was getting 60mbps now lucky to get 40mpbs.  I was advised to leave it 10 days and my speed should increase but it has not yet my stats are below.  I have had 3 engineers so far and BT are sending another one out this afternoon as they said my speed is under the minimum of 49mpbs.  Am I on a banded profile or something.
Product name:
BT Hub 6A
Serial number:
+084316+NQ65042542
Firmware version:
SG4B1000E020
Firmware updated:
10-Aug-2019
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
10 Days, 16 Hours 41 Minutes 34 Seconds
Data rate:
Maximum data rate:
13700 / 54298
Noise margin:
6.2 dB / 6.1 dB
Line attenuation:
40.4 dB
Signal attenuation:
26.6 dB / 40.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
245 GB Uploaded / 326 GB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-5HTS
Smart (Channel 11)
BTHub6-5HTS
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
Keels
pippincp
Message 7 of 12
Re: Any help please.
The answer is the same as it was 8 days ago when you last posted.
licquorice
Message 8 of 12
Nobody mentioned 10 days, it could take a lot longer for DLM to act. You haven't had a resync since you posted last so DLM hasn't done anything yet. It will eventually drop your noise  margin to 3dB and increase your speed. You are not on a banded profile.
licquorice
Message 9 of 12
You were advised to leave it until DLM kicked in, nobody advised leaving it 10 days. No idea where the figure of 49Mbps comes from, your handback threshold is 32 Mbps and you are way over that.
Not sure what you are expecting from the engineer, even if he requests a DLM reset (which is unlikely) it will only give you the same as you are getting presently as DLM has not acted so far you are effectively at the stage you would be at following a DLM reset. I.e a DLM reset will just put you back to square 1.
keels24
Message 10 of 12
It was bt who said about the 49 they said they not happy as my speed is under that and they are sending out the engineers I am not requesting this.  It was the engineer who said to leave it 10 days
Keels
