edarran
Message 1 of 16
Fibre Speed Dropping
Hi,
I have had fibre unlimited 1 for a few years ow and its always been pretty good, with speeds between 35-75, I was given a free upgrade to unlimited 2 a few months ago.
A few months ago I upgraded my smart hub from 5 to 6 and for the last few weeks I have been having problems with the speed.  The last few evenings I have noticed that the speed drops to around 1-25mb,  then in the morning its 60mb again?
I have reset the hub, had my line reset and been told to use the test socket.  The speed when I did was 166mb with network cable and 70mb on wifi.
Once the faceplate was back on, the speed dropped a bit to around 60mb but that was expected.
I did read a post which said do a test then unplug phone line and then test again.  I did this, it was 7.6mb and then 76mb afterward?
It just seems to go up and down constantly and I ave never had this issue before, any ideas anyone?
Thanks in advance
15 REPLIES 15
imjolly
Message 2 of 16
Re: Fibre Speed Dropping
can you post stats from hh6  advanved settings then technical log information
run btspeedtester and when first test completes then go to diagnostic test and post results  must be done with ethernet conenction and preferably with IE/Edge   if on FTTC then 166mb download speed is obviously wrong  http://www.speedtest.btwholesale.com/
enter your phone number and post results  remember delete number but leave exchange and cab  https://www.btwholesale.com/includes/adsl/main.html
edarran
Message 3 of 16
Exchange LLANSANTFFRAID is served by Cabinet 3
Results are:
Upload: 16.02
Latency: 32.88
Hope this is what you needed?
imjolly
Message 4 of 16
CStill need hub stats and dslchecker results
there is another post on same exchange. with similar problems from memory
edarran
Message 5 of 16
Product name: BT Hub 6A Serial number: +084316+NQ80605937 Firmware version: SG4B1000B540 Firmware updated: 19-May-2018 Board version: 1.0 Gui version: 1.64.0 DSL uptime: 0 Days, 2 Hours 49 Minutes 55 Seconds Data rate: 20.00 Mbps / 80.00 Mbps Maximum data rate: 26300 / 111880 Noise margin: 15.5 dB / 13.9 dB Line attenuation: 14.1 dB Signal attenuation: VPI / VCI: 0/38 Modulation: G_993_2_ANNEX_B Latency type: Fast Path Data sent / received: 8365 MB Uploaded / 22277 MB Downloaded Broadband username: bthomehub@btbroadband.com BT Wi-fi: Active 2.4 GHz wireless network name: BTHub6-K37N 2.4 GHz wireless channel: Smart (Channel 11) 5 GHz wireless network name: BTHub6-K37N 5 GHz wireless channel: Smart (Channel 36) Wireless security: WPA2 (Recommended) Wireless mode: Mode 1 Firewall: On MAC address: 34:6B:46:56:27:A7 Software variant: - Boot loader: 9.2.0
edarran
Message 6 of 16
19:31:43, 16 Jul.
:HTTP UserAdmin login from 192.168.1.68 successfully
19:31:13, 16 Jul.
wl1:Device <E4:E4:AB:1B:DD:2D> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
19:31:02, 16 Jul.
:HTTP UserBasic login from 192.168.1.68 successfully
19:30:44, 16 Jul.
BR_LAN:The DHCP options that are offered by the device (id:6): DiscoverOptions: 53,55,57,61,51,12 | DiscoverOption55: 1,121,3,6,15,119,252 | RequestOptions: 53,55,57,61,50,51,12 | RequestOption55: 1,121,3,6,15,119,252 | HostName: iPhone | VendorId:
19:30:44, 16 Jul.
:DHCP Confirmation of Request
19:30:41, 16 Jul.
wl0:A WiFi device <E4:E4:AB:1B:DD:2D> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
19:30:36, 16 Jul.
19:30:36, 16 Jul.
19:30:33, 16 Jul.
wl1:A WiFi device <E4:E4:AB:1B:DD:2D> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
19:29:29, 16 Jul.
wl0:IGMP join received for group 224.6.7.8 on interface wl0
19:28:17, 16 Jul.
19:28:15, 16 Jul.
wl0:IGMP group 224.6.7.8 on interface wl0 started by 192.168.1.69
19:28:15, 16 Jul.
wl0:IGMP group 224.6.7.8 on interface wl0 by 192.168.1.69 requested
19:28:15, 16 Jul.
19:28:12, 16 Jul.
wl0:Device <E4:E4:AB:1B:DD:2D> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
19:28:12, 16 Jul.
wl0:IGMP group 224.6.7.8 on interface wl0 ended by 192.168.1.67
19:25:21, 16 Jul.
19:23:21, 16 Jul.
19:21:12, 16 Jul.
19:19:11, 16 Jul.
19:18:19, 16 Jul.
19:18:18, 16 Jul.
wl0:IGMP group 224.6.7.8 on interface wl0 started by 192.168.1.67
19:18:18, 16 Jul.
wl0:IGMP group 224.6.7.8 on interface wl0 by 192.168.1.67 requested
19:18:18, 16 Jul.
19:06:47, 16 Jul.
eth2:A device has been disconnected from an Ethernet port (3)
19:06:19, 16 Jul.
ppp1:TR69 ConnectionRequest Failed
19:06:19, 16 Jul.
ppp1:TR69 ConnectionRequest: processing request from ACS
19:03:38, 16 Jul.
eth2:[Device Connected] MAC Address:54:ee:75:2a:9f:9f Host Name: Ed-PC IP Address: 192.168.1.77, lease duration is 86400 seconds.
19:03:38, 16 Jul.
BR_LAN:The DHCP options that are offered by the device (id:10): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,12,81,60,55 | RequestOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | HostName: Ed-PC | VendorId: MSFT 5.0
19:03:38, 16 Jul.
19:03:35, 16 Jul.
eth2:An Ethernet port is now connected (3/1000/FULL)
19:03:13, 16 Jul.
19:00:29, 16 Jul.
BR_LAN:The DHCP options that are offered by the device (id:7): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,12,81,60,55 | RequestOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | HostName: Ed-PC | VendorId: MSFT 5.0
19:00:29, 16 Jul.
19:00:26, 16 Jul.
wl1:A WiFi device <10:08:B1:3C:A1:B3> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
19:00:26, 16 Jul.
19:00:10, 16 Jul.
wl1:Device <10:08:B1:3C:A1:B3> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
18:59:14, 16 Jul.
18:59:14, 16 Jul.
18:59:14, 16 Jul.
18:59:13, 16 Jul.
eth2:An Ethernet port is now connected (3/100/FULL)
18:58:50, 16 Jul.
18:58:42, 16 Jul.
18:58:42, 16 Jul.
18:58:37, 16 Jul.
18:58:37, 16 Jul.
18:58:07, 16 Jul.
18:57:54, 16 Jul.
18:57:53, 16 Jul.
edarran
Message 7 of 16
Was that the info you needed?
imjolly
Message 8 of 16
Router stats look ok.  Max speed 80/20mb
can you run btspeedtester diagnostic test with Ethernet cable using IE/Edge and post results
edarran
Message 9 of 16
I did it yesterday at 7pm and got these figures, I can do again tomorrow and will post,
Upload: 16.02
Latency: 32.88
I do WiFi speed tests throughout the day, the morning is around 50-65mb download and is currently around 1-5mb as just tested.
edarran
Message 10 of 16
Hi, sorry misunderstood what you wanted.
Results Image not loaded
 1. Best Effort Test:
Download Speed : 26.37 Mbps
2. Upstream Test:
Upload Speed : 14.98 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
I then restarted the modem and got these results'
Download Speed : 58.24 Mbps
2. Upstream Test:
Upload Speed : 5.99 Mbps
I did do a similiar test a few days ago and did a screen shot if any use?
*Edited by Mod*
