Message 11 of 16
Re: Fibre Speed Dropping
Hi, sorry misunderstood what you wanted.
 1st Test
  1. Best Effort Test:
Download Speed : 26.37 Mbps
2. Upstream Test:
Upload Speed : 14.98 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
I then restarted the modem and got these results'
2nd Test
Download Speed : 58.24 Mbps
2. Upstream Test:
Upload Speed : 5.99 Mbps
I did do a similiar test a few days ago and did a screen shot if any use?
*Edited by Mod*
Message 12 of 16
 1st Test
2. Upstream Test:
2nd Test
2. Upstream Test:
 *Edited by Mod*
Sage
Message 13 of 16
You do realise that your resetting the router and running another "Further Diagnostics" test has now overwritten the one that shows a problem?
The only test result kept is the last one performed.
Message 14 of 16
apologies, I did it and then read the instructions which said to reboot it.
Just let me know what I need to do and when and I'll do it 🙂
Message 15 of 16
when your speed appears poor then run btspeedtester again and post results  that will be one recorded for BT to see
Message 16 of 16
Just a progress update, the speed hasn't dropped for several days so will monitor and test if and when it does.  Thanks for all advice and help!
