NeilO
Moderator
Moderator
Message 11 of 16
Re: Fibre broadband speed decreased
@curtisuk, Sorry my mistake it should be with you know.
curtisuk
Message 12 of 16
@NeilONo problem, I'm now facing an error saying I've sent the maximum amount of private messages. Is this because I tried to message you first before getting your message?
JohnC2
Moderator
Moderator
Message 13 of 16
Hi @curtisuk, sorry about that. I reset your message profile please would you try again and let me know how you get on.
cheers
John
curtisuk
Message 14 of 16
Great thanks, reply sent!
curtisuk
Message 15 of 16
Many thanks to the mods for resolving my issues, I am now back to my normal expected speed.
NeilO
Moderator
Moderator
Message 16 of 16
@curtusuk, brilliant I'm glad that's all sorted now Smiley Happy
