Mick109
Message 1 of 6
Fibre broadband
I live in a row of terraced houses 12 in total. When checking to see if i can get fibre broadband it says number 1 and number 2 can but it says i can't at number 8, any ideas why?
5 REPLIES 5
gg30340
Message 2 of 6
Re: Fibre broadband
Who is your present provider?
If you use this checker it will tell what cabinet you are on and what services it can receive. After removing your phone number, post a screen shot of the results.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If it does not show a cabinet number it will be because you are on an Exchange Only(EO) line. This means you can not get Infinity because you are not connected to a cabinet, instead you are connected directly to the exchange.
Use your phone number. If you don't have a BT number use the address checker. It is more accurate than the post code checker which can cover more than one cabinet.
RobbieMac
Moderator
Moderator
Message 3 of 6
Re: Fibre broadband
Hi @Mick109
Welcome to the Community and thanks for your post!
Just to add to the sound advice that @gg30340 has given you;  You can also use this link to contact Openreach about Superfast Fibre availability
Cheers,
Robbie
Mick109
Message 4 of 6
Re: Fibre broadband
Thanks for advice,
I currently have Virgin so do not have a BT line. Below is what came up when i did the address check.
BT BROADBAND AVAILABILITY CHECKER
Address SAVILE ROAD, ELLAND, HX5 0LY on Exchange ELLAND
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+
Up to 7
4.5 to 11
Available
WBC ADSL 2+ Annex M
Up to 7
Up to 1
4.5 to 11
Available
ADSL Max
Up to 5.5
4 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Availability Date
ADSL Multicast
Available
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Oct-2012; the Formal Retirement date for IPstream is from 30-Jun-2014.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note:
Thank you for your interest.
I cannot see a cabinet number so does this mean we are on Exchange Only then?
imjolly
Message 5 of 6
Re: Fibre broadband
yes if no cab number shown then you are connected direct to exchange and therefore no fibre broadband available to you
gg30340
Message 6 of 6
Re: Fibre broadband
It would appear that you are on an Exchange Only Line. When I checked some of the other addresses in your street they also came back as showing fibre was not available. Only number 1 and 2 showed that they were on a cabinet.
If you know your neighbours you could check with them if they have fibre or even a BT phone line and carry out the check on their number. That at least would confirm if it is an EO line.
