Message 1 of 3
Fibre installation different than traditional without external grey box?
Hi everyone.
Wanted ask about installations ways as the way ''external works'' done for me was different I was told and learned online.
So engineer removed one of two active copper lines ( to use its wall passthrough ) and straight from the telegraph pole installed wire *inside property . Not boxing it outside in that grey box but using small double pencil size housing ( I will attach photo) for wire indoors. Now I am still waiting for internal install.
So is this something common? Will this not mess up with some future works for property ?
2 REPLIES 2
Message 2 of 3
Re: Fibre installation different than traditional without external grey box?
Looks like a OFS compact Point of Entry box which is part of the OFS InvisiLight range. Believe Openreach usually uses this for MDU installations.
Message 3 of 3
No it’s not, it’s an internal splice point. Usually used if the property is an upstairs flat or for any other reason where it’s not feasible to fit the normal external grey box.
