Message 1 of 6
Fibre optic cable
Hello, I need to reposition my BT open reach white box inside my house.
So I need  to replace the fibre cable from the box on the side of my house to the box inside my house.
Where can I get this cable from?
5 REPLIES 5
Message 2 of 6
Re: Fibre optic cable
if you have FTTP then you need to contact openreach to do the work
Message 3 of 6
As far as I am aware you should not even think about doing that yourself. You will need to arrange for Openreach to do that.
Sage
Message 4 of 6
You can' t  buy the cable. If you need to move the ONT you will have to get Openreach in to do it.
Message 5 of 6
Sounds like Legacy FTTP so would be an EZ Bend Fibre Cable.
Openreach purchase these from a manufacturer in Mexico.
In order to joint the Fibre Cable you would need a Fusion Splicer and a Cleaver.
A good quality Fibre Cleaver will set you back about £150
A good quality Splicer like a Sumitomo Type - 71C like the ones Openreach use will set you back Retail £5000-£6000
Message 6 of 6
Oh, you’ll also need a Fibre Stripper, Splice Protectors and Fibre Cleaning Fluid.
