Message 1 of 2
Fibre optic line placement
Hello, I’m contacting to verify the placement and installation of two wires by openreach that appear to have been cut from hedge trimming, the wires come out from a ducting that’s above the ground and then reach over to the telegraph pole.
1 REPLY 1
Message 2 of 2
Re: Fibre optic line placement
this is a BT residential forum and no connection to openreach
try reporting to openreach
https://www.openreach.co.uk/orpg/home/submitFeedbackLoggedInUser.do
