Message 1 of 4
Fibre rollout
Hi,
Not sure if anyone can help but I hope they can. I’ve just moved into a 4 year old property and discovered that the cabinet I’m on doesn’t have Fibre. The cabinet 300m down the road however does. Is there anyway to know if I’m in the plans? There are a number of postcodes effected as currently have an almost unusable internet connection.
Nottingham Cab P63 in Mapperley is the one in question.
Please help
Neil
3 REPLIES 3
Sage
Message 2 of 4
Re: Fibre rollout
HERE's where you can check.
Message 3 of 4
Re: Fibre rollout
nottingham cab 63 is fibre enabled
Sage
Message 4 of 4
Re: Fibre rollout
Perhaps it's full.
OP can you enter your phone number HERE and post the result. Remove your phone number before posting.
