Micker
Message 1 of 7
Fibre speed
Hi i have bt infinity 2, was getting speeds in high sixties, modem started dropping connection and speed has dropped. Engineer out last week he changed modem, this one rebooted every 2 to 3 hours. BT sent a new one, but in the mean time i borrowed a 3rd party modem as i couldn't use my service. Speed is 48997, will this speed go back up or do i need what they call a boost engineer.
Stats from router:
Status
xDSL
Mode VDSL2
Traffic Type PTM
Status Up
Link Power State L0
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 4.4 6.4
Attenuation (dB) 17.7 0.0
Output Power (dBm) 13.4 7.5
Attainable Rate (Kbps) 44210 21045
Rate (Kbps) 48997 19999
B (# of bytes in Mux Data Frame) 195 237
M (# of Mux Data Frames in an RS codeword) 1 1
T (# of Mux Data Frames in an OH sub-frame) 0 42
R (# of redundancy bytes in the RS codeword) 12 16
S (# of data symbols over which the RS code word spans) 0.1269 0.3781
L (# of bits transmitted in each data symbol) 13117 5374
D (interleaver depth) 4 1
I (interleaver block size in bytes) 208 127
N (RS codeword size) 208 254
Delay (msec) 0 0
INP (DMT symbol) 51.00 0.00
OH Frames 0 0
OH Frame Errors 2158 132
RS Words 1732327996 628002688
RS Correctable Errors 195211664 123762
RS Uncorrectable Errors 0 0
HEC Errors 0 0
OCD Errors 0 0
LCD Errors 0 0
Total Cells 377187164 0
Data Cells 657854937 0
Bit Errors 0 0
Total ES 1442
6 REPLIES 6
imjolly
Message 2 of 7
Re: Fibre speed
With your noise margin at the reduced setting of 4.4db normally 6db you are getting according to stats faster that the attainable speed
can you enter your phone number and post results remember delete number.  https://www.btwholesale.com/includes/adsl/main.html
Is there any line noise. Dial 17070 option 2 should be silent and best with corded phone
Micker
Message 3 of 7
Re: Fibre speed
Hi thanks for quick reply, doesnt seem to be any noise on line with phone.
How I am getting more than max speed for line which is still way off what I was getting before these problems started about 4 weeks ago.
Have included web screenshot below:
imjolly
Message 4 of 7
Re: Fibre speed
your attainable is based on standard noise margin of 6db but as your noise marhin is lower at 4.4db givving you slightly faster speed   unlikely BT will help as you are currently within expected range but at bottom end
which exchange and cab are you on?
Micker
Message 5 of 7
Re: Fibre speed
Why has the speed dropped and not recovered back to mid to high 60s. BT says after faulty modem they will also do a follow up call to see if speed goes up still waiting. Will dslam put speed back up.
imjolly
Message 6 of 7
Re: Fibre speed
which exchange and cabinet are you on?
Micker
Message 7 of 7
Re: Fibre speed
Im on larne exchange on cabinet 13. Thanks agaon for your help.
