Message 11 of 31
Re: Fibre through loft to router
I've also heard of the maximum internal fibre run too.
Lingwood
Message 12 of 31
By sky I mean tv we cannot get sky broadband and I am away that open reach would run the cable / fibre
Lingwood
Message 13 of 31
The open reach guy that ran the fibre to the house said 30m plus along with this in the email from bt
On the day, your engineer can run an uninterrupted fibre cable (up to 30 metres long) to your home Hub from the box on your outside wall. This cable can only go along walls, both internally and externally, but not under carpets or floors - they may also need to drill some holes (as carefully as possible)
Lingwood
Message 14 of 31
I never said anything about make the connections! I would just aid in running the upto 30m of fibre
Message 15 of 31
I think the best/only thing to do with this is when the engineer comes to your property, explain to him/her what you want and be guided by him/her as to what is or is not possible because at the end of the day it will up to the on site engineer to make it happen.
Lingwood
Message 16 of 31
Generally my thoughts. I guess most people just have it through the front door / hall area but my house is a bit spread out and I need it central to cover for not only wifi for normal broadband but also for my sky q and 3 mini boxes
Message 17 of 31
the other alternative is to have the ONT near the front door and run an Ethernet cable from the ONT to the hub located were ever you want it in the house
Lingwood
Message 18 of 31
Yes a possibly, but if can get fibre there isn't that best?
I am sure a tea and or coffee will smooth the way
Biggest issue I have is just to get them here to do the work after they have cocked it up two Fridays in a row.
Going to book a Monday next time! Lol
Message 19 of 31
you will see no difference
Lingwood
Message 20 of 31
Thanks John 46
I will go for one more attempt of a day off work and see if can get fibre run
If not have it at front hall and I have a 30m Ethernet cable I can run
