I upgraded to fibre , everything was done ,bt engineer put all the equipment inside but could not connect to the hub as there was a red light on the box he said when there is 2 green lights just plug the hub in and it should just work, did tgat after a week when 2 green lights but the hub was flashing red and there was 3 green lights still trying to get it fixed , bt should of been out on moody but no show .
I upgraded to fibre , everything was done ,bt engineer put all the equipment inside but could not connect to the hub as there was a red light on the box he said when there is 2 green lights just plug the hub in and it should just work, did that after a week when 2 green lights but the hub was flashing red and there was 3 green lights still trying to get it fixed , bt should of been out on moody but no show . Had to go back to the old system at the moment
It doesn't matter how your hub is set until you change to FTTP. All it does is change port 4 from a LAN port to a WAN port. When you get FTTP, you connect the ONT (optical modem) to port 4.
Right, if the ONT is green you need to set the Hub to FTTP mode and disconnect the DSL lead.
If your hub was NOT set for Port 4 to be a WAN port (that is for full fibre, Fibre to the Premises, FTTP) then that may be why your hub won't connect when it's plugged into Port 4.
For Fibre to the Cabinet (your old system) it doesn't matter which way Port 4 is configured because it's not used to connect to the Hub.
I would set your Port 4 to WAN (FTTP) mode and try connecting to your hub again.
You can change Port 4 mode back and forth by accessing the Hub manager by typing 192.168.1.254 into a browser on a computer connected to the Hub, and switching "Full Fibre Mode" from "Off" to "On" and vice-versa.
