FullingMill
Message 1 of 17
Fibre with Halo - way off minimum speeds?
I recently upgraded to Fibre with Halo.  My estimated download speed was 41-67Mbps, and my 'Stay Fast Guarantee' speed was 32Mbps.
I am sitting right next to the hub, have tested in 3 times and my download speed has been between about 9 and 13.  This seems very poor and I am wondering what to do....formal complaint, send for an engineer, back out of the contract quickly during the cooling off period.
All advice most welcome....particularly as don't think I stand a chance of getting through to BT on the phone any time soon given higher than usual call rates/Coronavirus.
16 REPLIES 16
imjolly
Message 2 of 17
Re: Fibre with Halo - way off minimum speeds?
can you post hub stats  if hh6 then advanced settings then technical log information
is there any line noise  dial 17070 option 2  should be silent and best with corded phone
enter phone number and post results  delete number  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
FullingMill
Message 3 of 17
Thanks for your response.  How do I do the test?
FullingMill
Message 4 of 17
There is no noise on landline.....think new hub is a Smart Hub 2
NextGenG
Message 5 of 17
If you don't want to call in cant you report a fault via My BT?
FullingMill
Message 6 of 17
I logged onto the hub.....not really sure what I am looking at - says everything is operating fine.  Fyi, BT's own speed checker says I am only getting 12.2Mbps from their Exchange to the house....so that would seem to be where the problem lies and is well-under the 32 minimum they 'guaranteed'.
I get the feeling from other posts that there will be 'weasel words' they will fall back on.....and this is really an issue for trading standards as BT are NOT using plain or accurate English in their sales patter.
imjolly
Message 7 of 17
you need to post stats and dslchecker results so forum can help  instructions same for SH2  advanced settings then technical log information
FullingMill
Message 8 of 17
Is this what you need
Product nameBT Smart Hub 2
Serial number1942096786
Fireware versionv0.12.02.11078-BT (Sat Dec  1 14:50:22 2018)
Board versionR01
GUI version1.53a 29_08_2018
DSL uptime0 days 2 Hours 32 Mins 18 Secs
Data rate3Mbps/13Mbps
Maximum Data rate3 Mbps/21 Mbps
Noise margin9.3/10.8
Line attenuation9.3/20.5
Signal attenuation9.3/20.3
Broadband usernamebthomehub@btbroadband.com
BT Wi-FiActivated
2.4 GHz wireless network namexxxxxxx
2.4 GHz wireless channelAutomatic (Smart Wireless)
5 GHz wireless network namexxxxxxxxxx
5 GHz wireless channelAutomatic (Smart Wireless)
WirelessSecurityWPA2 (Recommanded)
Band steeringNo
Wireless securityMode 1
FirewallOn
MAC addressF0:86:20:B5:64:17
Software variant-
Boot loader 0.1.7-BT (Thu Nov 30 09:45:22 2017)
imjolly
Message 9 of 17
sorry but are you getting a dial tone?
need dslchecker results
FullingMill
Message 10 of 17
yes....dial tone good and on the phone now, very clear line.
